Piping network solution algorithms
I am familiar with hardy cross method for solving piping networks. Are there any other algorithms?
Piping network solution algorithmsPiping network solution algorithms(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Piping network solution algorithms
A good reference for these may be found in:
Analysis of Flow in Pipe Networks by Roland W. Jeppson, Ann Arbor Science.
You may also get some help from the documentation for EPANET; a free program available for solving pipe network problems.
Good Luck
from where i can get the free programme for network problems
http://www.usepa.gov
There is also a support forum located at:
EPANET-USERS@listserv.uoguelph.ca <EPANET-USERS@listserv.uoguelph.ca>
Good luck
thank you for your support.
http://www.epa.gov/docs/ORD/NRMRL/wswrd/epanet.html
Russ
Many people on this forum can answer your question(s) but you didn't state it clearly. The short answer is that when two pumps act in parallel you add their pump curves horizontally. Then intersect the combined curve with the system head curve to find the operating point. You'll find that you won't get twice the capacity of each pump but something less than that.
Try it and good luck.
Basicly, their algorithm are the same. The diffrence is each method use different equation (head equation, flow equation, dQ equation or combination the three of them)
It is not possible to calculate the coefficient of friction for different pipe materials. You can calculate it for a specific pipe material and diameter from measurement of flow, temperature and the head loss between two points and then by back calculation.
There is plenty of published data giving roughness measurements for different pipe materials (ks). Also most manufacturers provide estimates of roughness. Roughness is measured as a linear height mm and is typically in the range of 0.03 to 1.0mm. From the roughness the coefficient of friction (f) can be calculated from the Colbrook white equation.(found in any fluid mechanics text book but can only be solved by iteration - ).
From the coefficient of friction (f) the head loss can be calculated from the Darcy equation
h = f . l. v^2/(2.g.d) (again in any text book)
or you can go to
http://home.hccnet.nl/m.dijk/pressure_drop_calculator
and use the free calculator.
For general purposes, you can test the free version of FNESS (flow network evaluator for the steady state) which provides all sort of flow calculations in open and closed loop circuits based on the Finite Element Method. You can find it in www.figener.com.br
fvincent
If pipe size of 150NB is selected in place of 100NB,
PRESS DROP will be only 13.17% of original press drop.
Pipe Flow has a great new "3D interface" which makes it very visual and easy to use.
Good luck,
MVD
I have tried pipeflow 3D but I am not sure if it works on closed loop systems. How?
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
