Alluminum Alloys for pistons
I am looking for temperature dependent material properties for Alluminum Alloys. I know that a common used material for pistons is an Al Si Cu alloy. Please let me know if I am wrong and if someone know any links or books where I can find the properties.
thank you
RE: Alluminum Alloys for pistons
The specific type of aluminum alloy used depends on how the piston is manufactured-- forged vs. cast.  Forged pistons use wrought alloys like 2618 or 4032.  You can obtain information on these alloys from Matweb:
http://www.matweb.com/search/SpecificMaterial.asp?bassnum=MA2681
http://www.matweb.com/search/SpecificMaterial.asp?bassnum=MA4026
Cast aluminum pistons are manufactured using proprietary alloys from Mahle, Kolbenschmidt, etc.  They are alloys based on the Al Si Cu (3XX series in the US), with additions on Mg and Ni.  Alloys 332, 336, & 339 were the first alloys developed, and the basis for the newer, proprietary alloys.  Use Matweb for specifics on these alloys, and the following links for more information:
http://techtran.msfc.nasa.gov/tech_ops/nasa388alloy.pdf
http://techtran.msfc.nasa.gov/tech_ops/nasa398alloy.pdf
http://www.rsptechnology.com/sheet2.pdf
There are a number of reference books available with information on aluminum alloys.  The bookstore on the ASM International website is a good place to browse:
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/Topic.cfm&TopicID=6
