A2K4 Double Click Enhanced Att. Editor
I don't know if I like the Enhanced Attribute Editor yet. I would like to be able to double click an attribute and get the Edit Attribute dialog box. Does any one know of how to change the effect of a Double Click to bring up the Edit Attribute dialog box? By the way, in the Enhanced Attribute Editor, when you select a value under the Attribute Tab, you still have to select in the Value box just to type. At least in the Edit Attribute dialog, you can either Tab or Enter to proceed through the value boxes.
Charles S. Parnell
Southern Store Fixtures
RE: A2K4 Double Click Enhanced Att. Editor
http://www.cadforum.cz/cadforum_en/qaID.asp?ID=2583
Vladimir Michl, www.xanadu.cz
