Sequence circuit?
Sequence circuit?
Sequence circuit?
Hi all,
I am interested in making a circuit that will, in essence, be like a stepper motor circuit. The difference is there are three coils vs say a standard bipolar stepper with four or two coils. I think this rules out off-the-shelf solutions.
Here are the requirements:
There are 6 electromagnetic coils in a circular arrangement. The coils are wired in opposing pairs and need to be cycled to create a rotating magnetic field.
The coils are 3 Ohms each so 1.5Ohms in parallel. The inpedence is 100mH and the clock frequency will be varied from 10 to 500hz.
Power supply is 12VDC so ~8amps required; I think. I need to stay low voltage to keep the current in the range that will generate a strong enough magnetic field.
The part I need help with is how to build a robust sequence circuit that will cycle the three coils.
I think high current mosfets will handle the load and cycle times but again I am unsure how to make the circuit that would reside between the function generator and the mosfets.
Thanks Ray
RE: Sequence circuit?
Hi, there are plenty of off the shelf solutions, search for 3 phase motor control chips.
Thanks!
