batch plot HELP!
batch plot HELP!
I'm working in Microstation V8 and I am trying to send a batch plot. Everything is fine, except it would plot in landscape. Has anyone else had this problem, and if so, how have they gotten around it?
Help!
Help!
RE: batch plot HELP!
good luck
If so, are you using a PLT driver for plotting?
And if so, check the PLT driver.
Make sure the ...
rotate = ccw
And make sure your paper sizes are listed where the BIGGER number is listed 1ST!
Like so!
size=(17.0, 11.0)/num=0/off=(0.0,0.0)/name=11x17
size=(36.0, 24.0)/num=0/off=(0.0,0.0)/name=24x36
size=(44.0, 34.0)/num=1/off=(0.0,0.0)/name=34x44
size=(60.0, 35.0)/num=0/off=(0.0,0.0)/name=60x35
size=(21.0, 15.0)/num=0/off=(0.0,0.0)/name=15x21
Hope that helps.
