Shaft seals for radiation environment
I am looking for shaft seals to be used in a gamma radiation environment. As I understand, perferred materials are EPDM and ethylene-acrylic (Vamac). None of the big seal manufactures seem to be able to help unless I purchase a production run. I have new design application and also need to retrofit purchased parts with acceptable seals (gearboxes etc.). Anybody else solved this problem?
Thanks.
Thanks.
RE: Shaft seals for radiation environment
Call Tri-Tec Seals, Inc.
4141 West Grand Blanc Road
Swartz Creek, MI 48473
Talk to Brad
Tel. 810-655-3900
FAX 810-655-3322
E-Mail brad@tritecseal.com
Tell him Wayne Lovison from Toyo Pumps told you to call
have him call me at 815-806-1414 when you are done.
I use these guys when I have special projects and a limited amount of seals required.
I think 5 minimum order is there low end and they are very reasonable.
Good Luck
Wayne E. Lovison
wlovison@toyopumps.com
So far in my search I've found the following useful info:
John Crane has cartridge type contact seals that may work (though the seal material may be affected by radiation and thus may require regular maintenance). If leakage is acceptable, a simple labyrinth seal may work (no maintenance is required for this type of seal). The labyrinth can be designed with a specific number of "lands" to control the leakage. Only problem is that the leakage may increase if the shaft is not in motion.
