Convert doc to pdf using VBA
Can any one help for converting the Word document files to pdf files. Thank you.
RE: Convert doc to pdf using VBA
I'm not sure of anyway to do this in Visual Basic, but i have a program called "Publish PDF". You have to manuallly tell it to convert files but its fast and simple to use.
If you want files automatically converting inside an application then this wont help, but if just just want the ability to convert your Word documents into PDF then i recommend this program.
Cheers,
hojo
OpenOffice Ver 1.1 will read and write MS Office documents and will export PDF as well.  It is a free download from www.openoffice.org.
...John
Do a Google on PDF995 - it installs a printer driver that writes pdfs from any app that can print. Free for non-commercial use
Good Luck
johnwm
