Isolation plates and louvre dampers
Hi I'm working on an upgrade for a plant here in Queensland (Australia) and need to write a datasheet for inclusion in a specification. The sheet relates to a damper/isolation plate combination (both are needed, one for flow control, one for positive isolation). We would like a supplier to provide these as a single unit or at least a matched pair to minimise the amount of work required from us.
The ducting transports exhaust gas from an oil burner (for a boiler) and will be have design properties of 200degC, upto 5kPag & 13m/s and contains all the usual exahaust nasties (i.e. SO2). Duct is ~2000x2000mm square.
Ideally the supplier would be from Australia - the question is: can anyone here recommend some suppliers/manufacturers who I can contact to check their capabilities and generally discuss the issue? I already have Gosfern on the list of people to talk to.
thanks in advance
Aidan
thanks in advance
Aidan
