how to create suction lift (negative suction pressure)?
there are two ways of creating suction lift (negative suction pressure). one, by increasing the height of the suction pump suction level from the water tank (water supply) and another way is, creating different of pressure in the tank itself. so the variable here is Ps . do anyone know, how to make the second method possible? like using a vaccum pymp and create differential in the suction pressure from the tank itself. it is possible is order to find the pump's performance variation for different amount of pressures? can anyone give a guidance on how to setup ths procedures? thank you.
