Running in a Vacuum
Running in a Vacuum
I need help in understanding how If at all You Can force a Sytem to Run in a Vacuum. I am Do a very Low Temp Cap tube System and I want to beable to use the Refrigerant to its Fullest. I Don't know if All I have to Do is Make the cap tube restrict the flow So much or what? Grateful for Any Help
RE: Running in a Vacuum
Instead I would suggest you monitor evaporator temperature, and try adjusting the charge of refrigerant to obtain the lowest temperature you can get, and still cycle.
