CNC PostProcessor Help
We have 3 cnc machines now, 2 which are relatively new and one which is very very old. Its a matchmaker 750 CNC milling machine. We have it linked via serial to a computer which we feed the g code to.
We are having some problems getting a post processor to work with mastercam. We have a generic postprocessor from a matchmaker 850 series milling machine, but undoubtedly they are inherently different.
We are having problems with it understanding polar coordinates this is an example of a simple circle toolpath generated by mastercam using the postprovessor.
N100 G4 * O000026-06-03 *
N102 G4 *CIRCLE1 *
N104 G4 * TOOL 1 UNDEFINED *
N106 G40 T1 M3 S1000 ( ) 3 ( )
N108 G0 X30. Y12.
N110 Z-50.
N112 G1 X18. F500.
N114 G3 X6. Y0. J-12.
N116 X94. I44.
N118 X6. I-44.
N120 X18. Y-12. I12.
N122 G1 X30.
N124 Z-60.
N126 G4 M91
N128 G4 M90
It does not understand the coordinate system. Does anyone know what i need to tell the postprocessor to output in terms of polar coordinates.
Even better would anyone know where i might be able to get a postprocessor for this machine?
Thank you all in advance.
N102 G4 *CIRCLE1 *
N108 G0 X30. Y12.
N110 Z-50.
N112 G1 X18. F500.
N116 X94. I44.
N118 X6. I-44.
N122 G1 X30.
N124 Z-60.
N126 G4 M91
N128 G4 M90
RE: CNC PostProcessor Help
* Looking at your program, I don't see any M30 code to end the program. This may (or may not) be a problem.
* Polar coordinates aren't a given capability of every machine, but it sounds like you've used them on your machine before. I can only suggest looking at the reserved G-code values of G54, G55, G56, G57, G58, G59, or maybe G59.1, G59.2, & G59.3. (These are your coordinate system selection modal codes.)
* I've used MasterCAM before, and I can't say that I like it much. Seems that you have to do a lot of code hacking even after the post-processor to swag things into operation.
* I asked my local CNC guru, and he said that he couldn't find a post processor for a "matchmaker 750" out of his library of several thousand.
* Do you have a null modem cable hooked up between your computer and CNC machine?
Like I said, I don't know much of anything about CNC much beyond my own machines, but I hope I can help. If nothing else, maybe I busted a few new ideas loose for you.
I do have an end code G4 M2 etc, but had to add it at the end manually.
The machine is a Matchmaker 750, but it is controlled by a numericon 850 if that helps, maybe you have one of those in the library?
We do have an RS-232 cable hooked up to the thing.
It does not use the above polar coordinates, but does use V coordinates and also uses I,J,K with a radious function.
Maybe that helps a little more!
I is the circle centre x axis
J is circle centre Y axis
N114 does not quote I value the machine may need this value quoted.
Is there a setting in the post to force out all values, best to always output them all?
If you substitute the I & J with R (quoting the correct radius does it work?)
Be careful with R for radii > 180 degrees some controls then need to use I & J
