Assembly angle constraints.
Lets say I knew a guy that was building a hinge mechanism. Lets call him e.g. Dick. And he wants to constrain the motion of that hinge to only go between x degrees and y degees. What are some ways Dick could do this?
The guy I know says thanks in advance.
DickGiznya
DickGiznya
RE: Assembly angle constraints.
Every Year they add more features to the constraints, The version makes a difference if it is possible to get the requested functionality...
--Josh--
I forgot
Solidworks 2003 sp3.1
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
Construct appropriate linkage and attach to the mechanism such that the linkage limits the rotation.
Hide linkage.
We use this method now for hydraulic cylinders and doors that are supported by gas struts.
Option #2.
Wait for SWX 2004.
If not, I normally set a mate to constrain one of the angles I want. I then label that mate and suppress it. Then I move the parts to the next angle I want and mate it there. I label that mate. Now I can suppress or unsuppress either of the mates or suppress both for free hinge-style movement of the parts.
If this needs to be done dynamically, I'd love to know the solution.
Jeff Mowry
DesignHaus Industrial Design
http://www.designhaus-i-d.com
Both of my options were intended to allow dynamic angle limiting. Option #1 admittedly is not the best solution, but it works.
Thanks for the post. I haven't tried this yet.
How do you create linkage such that movement can be constrained dynamically? After putting some thought to it, I can think of some complicated mechanisms--anything simple you already thought of?
Jeff Mowry
Mike Wilson has some other interesting techinques for limiting motion. One of them is an angle limiter. Here is a link:
http://www.mikejwilson.com/solidworks/solidworks_files.htm
How about simply making a part that has a vee cut in it between the angles you need. Put it in the assembly at the hinge point and orient it in the desired direction. Then use the move component function pick on the part that is hinging and the part with the vee, select stop at collision and it will only move within the vee block.
