Mould Material for Cast Steel Rings
I am currently pouring cast steel into steel moulds that hydraulically open and close. There are 12 moulds on a carrousel that rotates. The product, approx 20mm thick rings with an outside diameter of max 600mm x 500mm inside diameter. The steel moulds wear quite fast. Any suggestions as to an alternative material for the moulds to be made from?
RE: Mould Material for Cast Steel Rings
Jesus is THE life,
Leonard
With steel mold you must be facing localised fusion of metal and then the mold needs to be dressed for damages. Also repeated heating and cooling causes cracks and scaling to occur .
