Ethylene glycol/water as buffer fluid
What are the advantages of an ethylene glycol/water mix over straight water as a buffer fluid. Presumably low freezing point and anti-corrosion properties are a plus point, but what about lubricity, viscosity and heat conduction?
RE: Ethylene glycol/water as buffer fluid
http://www.astseals.com/Barrier.htm
http://www.tc.gc.ca/tdc/summary/13400/13478e.htm
