Disc spring (Belleville) - alignment of contact faces
Application uses disc springs, but the contact faces of the springs are not perfectly parallel. Anyone know acceptable limits? Thanks
RE: Disc spring (Belleville) - alignment of contact faces
Thank you for your responses so far.
