MODELING SPREAD FOOTING WITH TIE BEAMS
In modeling reinforced concrete building, the most usual assumption is that the support will be fully fixed. But I wonder if this is true considering that there will be a movement of the support due to soil reaction. So perhaps maybe it is between fully fixed and fully hinge condition.
If we will place a tie beam, then we would like to make the tie beam carry the moment of the spread footing thus,making the the spread footing carry the axial load only. I would like to ask any suggestion of modeling the spread footing with tie beam in staad pro ,sap or any other software..
thanks
thanks
RE: MODELING SPREAD FOOTING WITH TIE BEAMS
