Editting Title Block in diferent tabs
How can I edit the tiltle block in diferent tabs automaticly
without going one by one?
RE: Editting Title Block in diferent tabs
make it an xref in each titleblock?
Hi...
One can make in AutoLISP, but I don't understand when you say title block...
Do you refer to the name of the block or some contained title in an attribute?, you specify to make the routine lisp... ;)
If it is attribute, it is necessary that you tell me the name of the TAG...
Un saludo de SpeedCAD... :)
CHILe
if not an xref, then put title block in model space (current drawing) and make viewports of title block for each layout tab, then modify model space title block and all layout tab tilte-blocks are changed. this way your title block can be within the drawing. but i prefer x-ref, no path, in current folder.
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
See here...
Thread555-38377
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
