PLC System Configuration help
I am using two PLC-5/80 as a redundant processors that is processing 7 SLC-5/04 I/O data through Channel 1A on the PLC-5 via DH+ communication. Also, Channel 1B is processing 3 remote I/O racks via ControlNet I/F module. And the communication between the PLC-5 CPUs are also ControlNet as well. A HMI package is communication to the PLC-5 Channel 0 via the Ethernet.
I would like to ask for help if someone out there had done a similar set up ? any help in terms of how to configure this system would be greatly appreciated. Thanks in advance.
RE: PLC System Configuration help
As far as the rest, Remote I/O is pain, we'd need to know if you have 1/4 rack, 1/2 rack, or full rack I/O and then you have to configure that information in the PLC5.
Good luck
Chris Elston
Automation & Controls Engineer
http://www.mrplc.com
Download Sample PLC Ladder Logic Code
at MrPLC.com
