Center Wheel on Mouse Stops Zooming
sometimes whilst using Autocad LT2002 I have noticed that the ZOOM function attributed to the center wheel on my mouse stops working. It starts schrolling instead. This change in function then stays with ther drawing file.
Why is this, and does anyone know a way of changing this back to the original zoom function?
D.
RE: Center Wheel on Mouse Stops Zooming
I use Windows 2000 Professional.
On your Desktop open My Computer, the Control Panel, Then Mouse, Select the Wheel TAB. You should have a Trouble Shooter Button to select. Follow the directions. You need to have the offending drawing open.
Charles S. Parnell
Southern Store Fixtures
Works a treat.
Thanks very much.
D.
