Remove parameters V5R9
Anybody knows how to remove the parameters/dumbify say an extrude made in the GSD so you get a surface, dead surface. Know that you can do that while creating extrude with the create datum option but I would like to get the same result after a parametric extrude is made.
RE: Remove parameters V5R9
I would try to copy the surface and then paste it in another OpenBody As Result. after that I would throw away the original surface.
Try it and good luck
Ola
