Converting V4 to V5 dwg
How do you fully convert a V4 dwg to V5 if you don't have the Project files that's linked to it? I'm currently using CATIA V5 and do not have V4. How do I relay to our customer the proper way of preparing their files (V4) so it would be compatible with V5? Any help would be greatly appreciated. Thanks!
RE: Converting V4 to V5 dwg
Check FAQ for this forum.
Fernando
Why dont you ask your customer to send you their PRJ files ?
And then set up V5 with that PRJ...
1 Environment for each customer...
or
only 1 Env for you and a script to change from one PRJ to the other... (I really don't know if that can be done because I didn't check if script or VBA can change that option)
Sounds not bad isn't it ?
Eric N.
catiav5@softhome.net
