Get index values from table array
I am using table parameters for applying varying pressure loads over nodes located on areas. I have mapped the area and some values of pressure over the refernce points have been set up on the table.
The problem is that i have to get the initial values of the zero column and zero row (index values) that i use for the interpolation and after trying it i never get the values of the positions (0,0), (0,1), (0,2)... I get instead the interpolated results with these input values....
Does anybody know how to get the values of Row & Column ZERO on any table parameter once they have been defined??
Thank you in advance
RE: Get index values from table array
It's so easy! parameter1=table(0,0); parameter2=table(0,1) and so on.
Where is the problem?
Let's suppose that we have the following table called "partable":
0 .5 1 1.5
0 11 12 13 14
.5 21 22 23 24
1 31 32 33 34
2 41 42 43 44
Note that Zero Rows & Columns are defined with indexs 0 .5 1 & 1.5
Suppose that I request for the second index value on zero column (Row=2, Column=0) (i want to be returned the value .5 corresponding with second index value)
If I request par1=partable(2,0)
par1 will be returned with value 41 and not yhe index value...
How can the index values can be retrived after being defined??
