Converting Beam Forces to Stresses
Question: What is the formula for calculating combined stress at a point in beam element NASTRAN?
Below is my hand calculation of the combined stress, and it is quite a bit different from the calculation from NASTRAN.  I am modeling an angled beam with force in the axial direction.  My input NASTRAN deck is listed below.  The calculated forces on element one are
Moment Plane 1: -21.239
Moment Plane 2:  21.239
Axial Force:     100
The areas and inertias (from FEMAP) are:
SHAPE    Angle (L) Section
Height    0.9    Width    0.9    Thickness    0.08
Area    0.1376
ShearAr 1, K1    0.42814
Shear Ar 2, K2    0.42814
I1    0.010665
I2    0.010665
I12    6.33E-03
J    2.90E-04
The distances relative to the shear center are
    Y    Z
Neutral Axis    -0.21239    0.21239
Pt 1    0.042146    -4.22E-02
Pt 2    0.042146    0.85785
Pt 3    -0.85785    0.037854
Pt 4    -0.85785    -4.22E-02
My calculation of combined stress is
Axial Stress = Axial Force / Area
Bending Stress = Bending Moment * L / I
Comb Stress = Sum of Axial and Bending Stresses
Axial Stress Calculation
            Axial
Point    Force    Area    Stress
1    100    0.1376    727
2    100    0.1376    727
3    100    0.1376    727
4    100    0.1376    727
Bending Momentent Stress Calculations
                        Bending 1
Point    M1    z            I1    Stress
1    -21    2.55E-01    0.010665    -507
2    -21    -6.45E-01    0.010665    1,285
3    -21    1.75E-01    0.010665    -348
4    -21    2.55E-01    0.010665    -507
                        Bending 2
Point    M2    y            I2    Stress
1    21    -2.55E-01    0.010665    -507
2    21    -2.55E-01    0.010665    -507
3    21    6.45E-01    0.010665    1,285
4    21    6.45E-01    0.010665    1,285
Combined Stress Calculation
    My Comb    NASTRAN Comb
Point    Stress     Stress
1    -287       3223
2    1,505     -1190
3    1,665     -1582
4    1,505     -1190
The NASTRAN deck is below
ID C:\Docum,FEMAP
SOL SUPERELEMENT STATICS
TIME 10000
CEND
MAXLINES=999999999
  ECHO = NONE
  DISPLACEMENT = ALL
  OLOAD = ALL
  SPCFORCE = ALL
  FORCE(CORNER) = ALL
  STRESS(CORNER) = ALL
  SPC  = 1
MAXLINES=999999999
SUBCASE 1
  LOAD = 1
MAXLINES=999999999
BEGIN BULK
$   Written by : FEMAP
$   Version    : 8.10
$   Translator : CSA/NASTRAN
$   From Model : C:\Documents and Settings\VorwaldJG\My Documents\h53\mw_060903\ramp 061703\test_beam_angle.MOD
$   Date       : Thu Jun 19 09:26:33 2003
PARAM,POST,-1
PARAM,AUTOSPC,YES
PARAM,GRDPNT,0
CORD2C         1       0      0.      0.      0.      0.      0.      1.+FEMAPC1
+FEMAPC1      1.      0.      1.
CORD2S         2       0      0.      0.      0.      0.      0.      1.+FEMAPC2
+FEMAPC2      1.      0.      1.
$ FEMAP Load Set 1 : Fx
FORCE          1      11       0      1.    100.      0.      0.
$ FEMAP Load Set 2 : My
MOMENT         2      11       0      1.      0.    100.      0.
$ FEMAP Load Set 3 : Fz
FORCE          3      11       0      1.      0.      0.    100.
$ FEMAP Constraint Set 1 : Fixed End
SPC            1       1  123456      0.
$ FEMAP Property 5012 : Blkhd6UpperCap1
PBEAM       5012  123456  0.13760.0106650.0106656.333E-32.903E-4      0.+PR  3V8
+PR  3V80.042146-4.22E-20.042146 0.85785-0.857850.037854-0.85785-4.22E-2+PA  3V8
+PA  3V8    YESA      1.                                                +PC  3V8
+PC  3V8 0.42814 0.42814                                                +PD  3V8
+PD  3V8                                -0.21239 0.21239-0.21239 0.21239
$ FEMAP Material 123456 : 7075-T6 Plate .04-.125
MAT1      123456 1.03E+7            0.33      0.      0.      0.        +MT 2N9C
+MT 2N9C  78000.  69000.  47000.
GRID           1       0      0.      0.      0.       0
GRID           2       0      1.      0.      0.       0
GRID           3       0      2.      0.      0.       0
GRID           4       0      3.      0.      0.       0
GRID           5       0      4.      0.      0.       0
GRID           6       0      5.      0.      0.       0
GRID           7       0      6.      0.      0.       0
GRID           8       0      7.      0.      0.       0
GRID           9       0      8.      0.      0.       0
GRID          10       0      9.      0.      0.       0
GRID          11       0     10.      0.      0.       0
CBEAM          1    5012       1       2      0.      1.      0.
CBEAM          2    5012       2       3      0.      1.      0.
CBEAM          3    5012       3       4      0.      1.      0.
CBEAM          4    5012       4       5      0.      1.      0.
CBEAM          5    5012       5       6      0.      1.      0.
CBEAM          6    5012       6       7      0.      1.      0.
CBEAM          7    5012       7       8      0.      1.      0.
CBEAM          8    5012       8       9      0.      1.      0.
CBEAM          9    5012       9      10      0.      1.      0.
CBEAM         10    5012      10      11      0.      1.      0.
ENDDATA
RE: Converting Beam Forces to Stresses
vorwald:  There are multiple ways to work this out; here's one way. From the given data, it can be seen that, from vector addition, you are applying a moment of M = -sqrt(21.239^2 + 21.239^2) = -30.0365 about the weak principal axis. It can also be figured out that the minor principal moment of inertia is I = 0.004332047. And the corresponding extreme fiber distance is c = -0.3599667. So the maximum normal stress on the cross section is sigma = M*c/I + P/A = 2495.85 + 726.74 = 3222.6, occurring at point 1. Similarly, the fiber distance at point 3 is +0.3329980; substituting this for c in the above formula gives sigma = -1582.1. Likewise, the fiber distance at point 2 (and 4) is +0.2764294, giving sigma = -1189.9. Therefore, all four stress values labeled "Nastran Comb Stress" are exactly correct; all four values labeled "My Comb Stress" are incorrect.
