Triple taper solids
Triple taper solids
I'm hoping someone can help. I've tried without success to creat a tapered solid, using AutoCAD 2000. It is supposed to end up looking almost like an ellipse, that tapers in length, and height as it is extruded, almost like an airplane wing, with a varying ratio between the height/width. (i.e. starts at 12 long and 3 tall, and ends at 4 long and 2 tall, and the back edge tapers forward twice as far as the front tapers back) Any hints?
RE: Triple taper solids
