AUTOCAD XREF NOT FOUND
I made some *.dwg drawings on my computer, but I'm sharing these files with another partner, so he has his own copy of them. We use Autocad R14. The problem is that all of them are xref files, so every time he opens a drawing, it is *empty* cause the xref can not be found. He's added in the autocad preferences under "proyect files search path" the new folder where he saved the drawings. In adittion to this he used the projectname to set up his drawings in order to make them appear in the screen, but at this point he hasn't been able to see any drawing, because autocad doesn't follow the new search path names. Could you help us, telling us what we can do to solve this problem? We dont want to change one by one the path name..it will take too long!!
I'd appreciate your help. Thanks
RE: AUTOCAD XREF NOT FOUND
I thik this is all i can tell you, hope it can help you.
Good Luck!
www.autodesk.com which is the website of autodesk company the creator of autocad , I hope you can find a contact email address at this website.
