NEED TECH-TABEL FOR 1 IN A36 ON TRUMPF 6030
IS THERE ANY ONE OUT THERE RUNNING A TRUMPF L6030 4000WATT THAT HAS A TECHTABLE FOR 1IN MILD STEEL AND HAVE HAD GOOD PROCESSING RESULTS WITH IT?? ALSO ARE LOOK FOR A TECHTABLE FOR PROCESSING WOOD ON THIS SAME MACHINE!!
RE: NEED TECH-TABEL FOR 1 IN A36 ON TRUMPF 6030
to supply that information.
I run a L3030s 4K, and I use the following (copy and paste into your PLT4000.LST):
DA,'19917','TC8',4000,'ST-100',25.4,7.5,'2.300000',4,0.0,0.0,2.0
* ,2.032,2.032,0.5,100.0,1,1,0.508,4000,10000,0.6604
* ,1.016,1.0,3000,100,0.254,5.08,0.6,0.508,500,15
* ,0.0254,1.016,1.0,3000,100,0.254,5.08,0.6,0.508,500
* ,15,0.0254,1.016,1.0,3000,100,0.254,5.08,0.6,-8.0
* ,3.0,2,7.874,9.0,1,2.0,0,15.0,20,7.874
* ,9.0,1,0.5,0,2.54,0.0,38.1,200,10000,5.08
* ,2,2.0,-6.0,6.096,160,1000,2.54,1,2.0,-3.048
* ,3.048,140,1000,3.048,1,2.0,0.1,1,3.048,1
* ,2.0,-3.048,0.2,1,3.048,1,2.0,0.6,1,3.048
* ,1,2.0,100.0,2.5,2.5,2.5,3.0,3.9624,0,0
* ,0.0,0.0,0,0,0.0,0.0,0,0,0.0,0.0
* ,0,0,0.0,0.0,0,0,0.0,0.0,0,0
* ,0,0,0.0,0.0,0,0.0,0.0
You owe me one!!!
also have you ever cut any wood on your machine??
Would you be so kind to explain how that tech table works if it's not too much to ask?
thanks
msandoval
