Source for electronic cases (box)
Does anyone know of a source for a box to fit some electronics devices (PCB, etc.) in with a terminal block on top.  The approx. size I'm looking for is about 4.25 wide, 3.50 deep and about 3.75 high.  The case can be from plastic, temp at 80C
thanks in advance.
RE: Source for electronic cases (box)
Many to choose from. Start with Phoenix Contact and Polycase. Phoenix is likely to have what you need (terminal block box) already. Polycase would require some work on your end to use TB.
Got all the new surplus mags?  Electronics Goldmine, Meci, All-electronics, etc. You might find one in one of them.  Good luck!
