Geogrid supplier
Geogrid supplier
Geogrid supplier
I need to find a supplier of geogrid to build reinforced earth retaining walls.  This supplier should provide information on design of walls using their product.
RE: Geogrid supplier
There are so many suppliers out there that you can throw a stone in any direction and hit one.  Where are you and do you have a material preference?  i.e. HDPE or Polyester?
Oh I also forgot to add that you should probably post this in the geotechnical engineers section under earth retention engineering.  I work for a distributor so I don't want to be biased here so I will throw out some manufacturers and you will have to find a local distributor.  Mirafi, Tensar, Maccaferri, Huesker ..... etc.
Thank you for your reply. I am located in Honduras, Central America. I have no preference on the type of material to use. I have no experience with either. The most cost efficient ensar system here in Honduras and apparently, they hold exclusive representation of the system.  If you can provide me with several web pages to investigate, I would appreciate it.
Well if you would like to can look at our website www.geomembranes.com , we are located in Canada, you can also look at the manufacturers websites for Mirafi, Tenax and Huesker all of which we carry, and for Tensar, Maccafferi and Strata which we do not and you will have to find some other distributor.  There are a few more manufacturers but those are the most of the major ones.
honduras, I am an independent consultant who formerly worked for a geogrid mfgr/distributor.  I can design for you; otherwise, simply enter the tradenames of various geogrids into the search function of your favorite web browser and hit enter!  example: Miragrid, Stratagrid, Fortrac
D. Bruce Nothdurft, MSCE, PE, PG, M.ASCE, etc, etc,...
Principal Engineer/Geologist
Atlantic Geoscience & Engineering
Charlotte, NC
