Thickness range for WPS
We have a PQR using 2 processes for P-No. 8 Group No. 1 to itself qualified with impact testing using a plate with 1” thickness. GTAW was used for root passes deposited weld metal was 3/16”, filling was done with SMAW deposited weld metal was 13/16”. The PQR was done w/o PWHT as per Sect. IX.
Now I want to issue a WPS for the same P-No. Group No. with a GTWA root and filled with SMAW. What is the acceptable thickness range assuming that Sect. IX applies
and impact testing is a requirement?
Ralph
r4lph_CAD@yahoo.de
Ralph
r4lph_CAD@yahoo.de
RE: Thickness range for WPS
Base Metal Weld Metal
.1875" ~ 2T 2T
Where T is the thickness of the test coupon
The APIGUY....
5/8" to 2" (see QW403.6)
2. Weld Metal qualified(See QW 451.1)
2.A. GTAW
3/8" MAXIMUM
2.B. SMAW
1 5/8" MAXIMUM
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
End of all knowledge is the attainment of immortality!
I'm not sure I agree 100%. According to r4lph, PWHT was performed and therefore 403.6 does not apply. P8 is austenitic and should be solution annealed according to that same section. If you follow all of the references and footnotes out, you wind up at QW 200.4b. The second sentence states " In this case, the process recorded on the first PQR may be used to deposit the root layers using the process(s) recorded on that PQR up to 2T in thickness on base metal of the maximum thickness qualified by the other PQR(s) used to support the WPS.
Please advise if I am missing something somewhere.
The APIGUY....
I checked the code again and I should follow sayeeprasadr's
suggestion.
Thanks again and greetings from Austria
Ralph
The APIGUY....
