Pro-e and material properties
hi there,
 why is it that pro-e uses units for some of the material properties that i have never came across before.
thermal conductivity for instance i would say (w/mK) was a good one but proe has (inlbm/(sec^3F)) maybe its just me but i have a hard time converting them any one know a good way to convert them (web site of something)?
maybe its just me being stupid
cheers
RE: Pro-e and material properties
Pro/E default setting is in-lb-F (imperial). You are using SI units.
Check the following site where you can find a lot of info  materials and their properties either in imperial and SI units.
www.matweb.com
-Hora
i use si units,  i have used matweb before (brilliant)but you will find all thermal conductivites in w/mk
cheers again
What you need to do is setup a user defined set of units for the part.  I am not sure if you will get what you want, but it is worth a try.
Go to the units menu in your part (Setup --> Units).  From here you can setup a new set of units (non-standard).  When you do this you have the option to define each unit for each type of measurement.  You can specify length to be inches, time to be seconds, mass to be kg, temperature to be Celcius, etc.
You should be able to define the unit of measurement needed, so that you will not need to convert when using Pro/Mech.
Good luck!
Take care though. Changing units used in Pro/E can change your whole sketch. There's an option to check to keep your sketch dimensions or to convert them into new unit.
Cyril Guichard
Mechanical Engineer
