LNB'S
LNB'S
IS A LNB'S USEFUL LIFE GOING WHEN SPARKIES APPEAR ON THE TRANSPONDERS ON LOWER POSITION SATELITES, THAN HIGHER ONES? ALSO, RAIN BLANKS OUT MY SIGNALS ON THE LOWER ONES SUCH A G5 THROUGH F7, BUT SIGNALS ARE GREAT ON THE UPPER SATELITES, SUCH AS GO THROUGH W6?
RE: LNB'S
RE: LNB'S
I am using a 20 Deg. LNB for a 10 foot fiberglass dish, feeding a 4DTV receiver. The LNB is some five years old. I have peaked the dish with the signal indicator on, and in the past I have been able to get a good picture. My logic was that if the transponders were all the same as frequency, then changing satelites should not make a difference. Is this logic sound?
RE: LNB'S
