This should be an easy one...
I am relatively new to SW99, and for the life of me, I can't find a way to turn off the visible dimensions for a part (or a series of parts in an assembly). I can easily find the switch to turn on and off construction plane, axes, etc...but dimensions? A quick tip here would keep me from going nuts! Thx.
RE: This should be an easy one...
To turn it off permenantly you have to set that up in your Tools\Options. I don't remember excatly where it is in SW99, but it will be located under Annotations...probably under Document properties.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
Sean
2)Under Detailing go to Annotations Display.
3)Un-check Display all types.
4)Un-check Feature Dimensions but leave everything else that you want displayed checked.
5)Check Display Annotations, near bottom of dialog box.
Let us know if you get the desired results.
Cheers,
Jay
I maybe wrong though, since that was 4 years ago. A lot has changed since then.
Scott Baugh, CSWP
FAQ731-376
Got it...it was in the options...I just didn't dig deep enough. Thanks to all who helped.
Sean
