hook style anchor bolts
I am a design engineer for a metal building fabricator and have repeatedly run into the question of how to consider the hook on a cast in place anchor bolt into the strength for uplift. For bond strength to the anchor surface I have always used 160psi on the vertical area only ignoring the hook. How much help does the hook offer?
I see where publications such as 'Design of Headed Anchor Bolts' is suggested in other postings. Do any of the publications address hook type anchors.
Thank in Advance,
OzarkMtbr
Thank in Advance,
OzarkMtbr
RE: hook style anchor bolts
