Autocad HIGHTLIGHT over image or vector
In an App called XMAP or 3d topo quads... you can draw an area over somewhere on a map and it would highlight it with a bold regular line on the perimeter of the area. in the Area inside the Perimeter it is like a SOLID HATCH but translucent so you can still see the area.
Is there a way that autocad can do this? or a lisp...
Thanks for the help...
RE: Autocad HIGHTLIGHT over image or vector
You can draw a square over an image and do a "cross hatch".
Then do a "draworder" and send the hatch to TOP over the image.
That's one way
Another way would be to ...
Go into Paint
Draw a SOLID red (or whatever) square
Save as a BMP
Exit PAINT
Go into AutoCAD
Image Xref the "Paint" block.
Place it over the image and play with the properties (tranparency)
You might have to do a "draworder" here too!
