About general cable
About general cable
I having some difficulty to select cable for my work station. Can anyone provide me information or website abt different type of cable.....mm twisted pair, coaxial, fibre optic...what is the maximum range and data attenuation lost
RE: About general cable
TTFN
The "best" cable is question is requires knowing what the "best" solution is for your particular application. For example, fiber requires transceivers on both ends as added costs. Is cost not relevant?
TTFN
If you require longer distances, go with multi-mode fiber. MM fiber is good up to 2Km, depending on the ehrtnrt to fiber interface you choose.
