Chlroine Pipe Tichkness
We use chlorine to filter out impurities from aluminum and recently we were audited on our system.  The auditor stated we need to adopt a program to monitor wall thickness for the pipe.  I know chlorine will wear pipe walls at high velocity and with water.  Can anyone suggest where to measure at?  I am looking at 3x dia and 4 points along the circumference.  Is this too much?
Thanks...
rdeno
RE: Chlroine Pipe Tichkness
rdeno,
If this is erosive/corrosive service, I suggest determining which elbows of the system have the highest velocity and monitoring those.
I would only inspect (UT) the "downstream half" of the elbows for metal thickness.
EPRI, some years back, developed a piping inspection program for feedwater piping systems. Within that program were guidelines about selection of points for piping wall thickness verification.
Is this a stainless steel system ?
If so, is this 5S or 10S stainless piping ?
MJC
The pipe is 3/4" CS, SW.  The total length is approximately 500 feet long ranging to ground level to 50 feet above.
How do you mean "down stream?"
Also, I am looking at a StressTel T-Mike EL datalogging as my ultrasonic thickness gauge.  Have you a personal experience with them or do you recommend another product?
