Battery Disconnector
Can anyone please help to sketch me a circuit diagram about electronic battery disconnector(solid state).
This is use to disconnect the battery from the oads when it crashes. Dont worry about the specification.
Any idea is wellcome
RE: Battery Disconnector
1. A solid state relay may be used with the current sensor over the shunt resistor.
2. The current sensor would include another solid state relay that actuates on high battery current that is sensed in terms of higher voltage across the shunt to actuate the solid state relay. The solid state relay would open its contact and interrupt the power solid state relay turn on supply. Then, the power solid state relay would open the battery circuit, thus protecting your load and battery.
if so a traditional relay ie:drive the coil of it from a mosfet or bipolar and seperate the load current from the control current. if you use a solid state relay you can obtain isolation from an opto-coupler and source the relay control from a second winding from the control ckt power supply
