AutoIsogen
AutoIsogen
Has anybody extracted isometrics by line command at_igenx.exe? If you run this command from command line, it uses default input files. If you want to use customized input files, this command needs to know that the computer has AutoIsogen Plus license. So, is there any way to give this information to the command?
