Compact fluorescent lights
Hi
I am looking for a dimmable compact fluorescent light source. I have a small portable fluorescent light which has a F4T5/C tube installed and runs on 4-AA 1.5 volt batteries and draws 400 ma. In addition to the batteries there is an external power supply plug for a 120 to 6 volt adapter. I connected an adjustable power supply to this plug and began to experiment with lesser voltages to see what would happen. I found that the lamp would not start at the lower voltages. It would start at 6 volt and would get progressivly dimmer as i reduced the voltage. I think that this light will work for the project i have in mind. My question is does anybody have any ideas on the long term affect of running these fluorescent tubes and ballasts at lower the design voltage?
RE: Compact fluorescent lights
Need more info? <nbucska@pcperipherals.com>
http://www.thomasregister.com
and contact the fluorescent light dimmer manufacturers' reps for more/special info
