Install ai series (icom) with RsLogix5
I have installed RsLogix5 with RsLinx (Light version).
Now I want also install the AI series software (ICOM)
for the PLC5 on the same pc.
But the ai series used also the EVRSi.sys and 386swap.par hidden files for the license key.
Can I install these ICOM software?
Can I used the license key of RsLogix5 to make the ICOM
software working?
Greetings,
mulderm
RE: Install ai series (icom) with RsLogix5
Depending on what version of software, yes you can, install A.I. Series software on the same computer as RSLogix. If the DOS software is ICOM(before Rockwell bought it), then I'm not sure.
As your second question, concerning using the RSLogix licence to run A.I. Series software, no. You will need a licence for each software.
