welding modelisation with patran
Can someone tell me what is the best type of MPC (or an other feature) that can represent the behavior of 2 welded parts ??
I planned to use explicit MPC's, but I 'm not sure of that ...
regards.
nicolas
regards.
nicolas
RE: welding modelisation with patran
It is a bit late but I use RBE2 to model welding between two parts in Patran, usually node to node (I mean one to one). It is not important how you define independent and dependent node, but be sure to constraint 6 dof.
The thing is that this RBE2 MPC restraints traslations (forces) and rotations (torques) in the correct way.
Hope that helps you
