Anchor bolts - Galvanized or not?
We are designing and supplying anchor bolts for a derrick and an elevated flare stack. We are not designing the foundation. Location is in Qatar (Middle East). No corrosion allowance has been incorporated in the design of the bolts. These bolts are 1" and 2" diameter A36 threaded rod. There is no harsh environment, bolts are just exposed to the weather.
Are anchor bolts normally supplied galvanized or at least are the exposed ends galvanized?
RE: Anchor bolts - Galvanized or not?
