Data Translation
Data Translation
Data Translation
Can someone suggest me the reliable format which can be used to translate a solid CAD to Pro Engineer 2001 and to Catia V5 (with minimum data loss)
Thanks in advance
RE: Data Translation
I use STEP files.
There are some hidden config.pro options that will allow 2001 and Wildfire to export Parasolid files. I think Wildfire can also import them. Haven't tried it, yet.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Ben:
I would be interested in learning more about the hidden config.pro options that you mentioned for ProE to export Parasolid data.  Would you care to elborate?
Talbot Teboe
Cad Design
J.L. French Corp.
enable_parasolid_export yes
Ben Loosli
Ingersoll-Rand
Ben:
Thank you, this will be of use.
Talbot Teboe
Cad Design
J.L. French Corp.
