Minimum Reinforcement-Precast Slabs
Can anyone help me in determining required minimum reinforcing in a precast slab. The slab in question is a cover for a pit. Loads are not significant. Minimum reinforcing governs the design. ACI code doesn't address this issue specifically.
RE: Minimum Reinforcement-Precast Slabs
Minimum ratio of reinforcement area to gross concrete area is often specified at 0.0020 for deformed bars; maximum bar spacing of 12" center to center; minimum bar size #4.
