can you change drawing references
Is there a way to change the solidworks part file that a drawing references.
RE: can you change drawing references
Open the drawing in SolidWorks Explorer.  You will see a list of the drawing references.  Right click on the icon for the drawing reference file and pick "Replace".
I may make you feel, but I can't make you think.
You can also do a file open then single click on the drawing you want to change references.  Next press the References button and double click the file under "New pathname".  Then browse to the model you want as the new reference and either double click it or single click it and press the open button.  You should return to Edit Referenced File Locations dialog.  Now press the OK button.  Finally press the Open button from the Open dialog.
The drawing should open with the new model you selected as the reference.
We do it the way Regg exaplined which works well for us.
BBJT CSWP
