Quick Question... Excel Intergration
Question...
Is Excel possible to link a CELL (A1) into other MS products and what ever is updated on the EXCEL cell will UPDATE where it is linked in the other MS products?
one step further...
Can it intergrate into other NON MS products like Autodesk... and if so... how?
thanks
RE: Quick Question... Excel Intergration
Yes, Excel can integrate with anything that is OLE compliant (= supports Automation).
So in Word, for example, you can Paste Special, then select the option button Paste Link, and paste as Formatted Text, or whatever you like. Give it a try and see what works for you.
In Autocad it basically works the same, Paste Special and select the Paste Link option button.
Good luck!
Cheers,
Joerd
How about non OLE Objects??? can it link this way as well?
thanx
