evaluation of foundation condition under a building
Dear Sirs,
I am looking for information about evaluation of foundation condition under a building for determination of volume of improvement work for increasing the bearing capacity (foundation improvement for prevent the failure or deformation).
As i understand it can be achieve by means of Cone Penetration Test methods (CPTU, SCPTU & etc) and by some distance sensing.
Could you be so kind to help me to find the peaple who may concerning following question.
Thank you in advance for any information following this question.
Best Regards
Maxim Shokalskiy
PS Your reply and advice is very important for me.
Best Regards
Maxim Shokalskiy
RE: evaluation of foundation condition under a building
Yes, there are several ways to evaluate. The most common is to use the same methods you would use for design geotechnical investigation, assuming access is available at the perimeter of the building and perhaps even placing a boring inside the building.
Maxim
Do you know any sites according this subjects?
Impruovement foundation etc
I recently did a project where 4 stories were being added to a hospital building, thus increasing the loads on the existing footings by 50%-100%. Traditional underpinning was specified, but physically impossible due to access and groundwater. We installed jet grout columns, through the existing footings, to a depth of -40' in order to increase the capacity. Worked very well.
Please provide details about your site and structure - we need more information in order to really help you.
A few times in the past we have performed CPT tests on existing buildings in order to assess unusual amounts of settlement which are happening. On other occasions CPT testing of this nature has been conducted in order to examine the possibility of adding more floors to an existing structure.
The process: A small hole is cored in the floor slab and a mini cone pushing unit is bolted to the slab. Hydraulic power is supplied via a power pack or hydraulic lines connected to the drill rig outside.
The mini cone pushing units are small enough to be wheeled into a office or underground parkade. Some companies also have mini drills and soil samplers which can be deployed within very tight spaces.
Check with Fugro as they have quite a variety of CPT testing tools and minature soil sampling equipment.
Best of luck
Coneboy
