B31.3 relief valve requirements
B31.3 appears to require the use of ASME UV-rated relief valves for thermal relief of trapped line segments.
I have an application using 1/4" to 1/2" tubing on a supercritical CO2 application, and would prefer to use non-UV rated reliefs, which are cheaper and readily available. Trapped volumes are on the order of 5-10 ft of tube length or less.
Can anybody advise as to the necessity of the UV reliefs?
RE: B31.3 relief valve requirements
Good Luck. . .
