Bolt holes in compression members - net area
Is there a basis for looking at the net area due to bolt holes in a compression member?  To compound matters, these are slip-critical bolts.  The holes would be located a significant distance from the ends of the compression member.
Intuitively I would assume that any localized stress increase at the bolt hole location would not be a big concern for pure compression, particularly for a bearing connection.  In my brief scanning of the ASD and LRFD manuals, as well as Salmon and Johnson, this seems to be the case.  However, for a slip-critical connection I'm not so sure.  Any advice would be greatly apprectiated.  Thanks so much.
