Insert Drawing Sheet
SW 2003. Hi Guys. In an existing multi-sheet drawing, is it possible to insert a new sheet and have it be added to somewhere other than the end of the drawing? I have a 9 sheet drawing that needs a new sheet one and so far as I can tell I'm going to have to re-draw, from scratch, all 9 sheets just to move 'em back one. Please tell me I'm wrong.
Tanx in advance!
Tanx in advance!
RE: Insert Drawing Sheet
Create the new sheet at the end of the feature tree, then you can highlight the sheet name and drag and drop it to the top. You will probably have to rename your sheets. Also in SW2003 SP1.0 it shows the icon like you can't drag and drop but it does work, just ignore the icon.
mncad
Cheers.
